uclalumni00
Hi,
The sprinkler valves coming out of the ground sit adjacent to a concrete portion of the wall at the base of our home, in our backyard.
I noticed water pooling in that hole where the valves sit. There's a leaking pipe under there.
I scooped out all the water, and the water pooled back in 20 minutes (without turning the valves on or anything), but the water level doesn't ever rise above ground.
I was quoted $400 to fix the situation. Money is tight.
The water never rises out of the hole, so can I just leave it this way? Any downfalls besides mosquitos, bugs, and slimy mud?
The water sits right up against some concrete, which is at the base of the house. Which seems slightly concerning but ok at the same time, as it seems that the builders have designed the valves to reside there, even though it's obvious that water and leaks are common wherever you stick the valves.
Additionally, it has already been this way for months and seems fine.
We'd like to maybe delay fixing for 1-2 years if possible. The water bill doesn't seem that affected.
One thing I don't get: why does the water fill back up right away, but yet the water doesn't ever rise above and out of the hole onto ground level?
