Is Cellular PVC OK in 4" Stack
DigitalJim
Rochester, NY
I am replacing a short section of 4" stack with a new tee followed by a new wye (for use as a cleanout). The tee will mate with the existing cast iron at the floor using a compression donut. Everything above this point is currently PVC.
I bought a short piece of 4" PVC to connect up the fittings and transition into the cast iron. When I went to cut it, I realized it was cellular core PVC DWV (it cut way too easy), which I have never used before.
Is this OK to use for these short transitions on the main stack? I am in Rochester, NY.
Thanks in advance for replies.
Jim
