Input On Hunter Pro Spray Irrigation Heads
Wpollock
Texas
I posted this in the Landscape forum before seeing this forum and will try to delete it from there if possible since my question clearly belongs here.
I need to adjust and probably replace several heads due to installing some garden boxes and a deck extension to minimize water waste.
my first thought is to change the coverage pattern and reduce the throw distance to see if I can stop needlessly watering the boxes and deck. To do so requires setting the left side stop on the head and then the coverage area and throw distance. Can someone please explain where I should stand to determine the left side stop for any head?
Thank you
WorthFlorida
Solutions
Orlando, 32828
Thank you
Really I do not understand your question. The left stop is fixed inside the sprinkler. Just rotate the sprinkler to where you want the left stop. You can unscrew the top of the sprinkle, pull out the workings and reinstall in.
