davideliarosenbloom
Currently running a SS 60 gallon INDIRECT DHW supplied by 1.25" piping and a 15/58 circulator set on speed 1. Cannot get a 30 degree Delta T in system at any temp and wonder if its speed through the system being too fast.
Does anyone know what the best indirect DHW tank can perform at as far as BTU absorption>? Would it make sense to use the ball iso valves as restrictors and see if slowing the flow increased heat absorption? Could the heat exchanger tubing which is quite large be coated from 20 years of use? Is the latter more likely than not?
thanks,
Dave
thanks,
Dave
