who4ever
I have around 20 Hunter PGP rotary sprinkler heads on my property. The system is 12 years old. Many of them have puddling around the heads. When I look closely it seems that the puddling is due to the nozzles not shooting a nice jet out of the sprinkler or due to water spraying out from the perimeter of the nozzles. I was wondering if nozzles wear out in time and need to be replaced. I have a couple of nozzle trees and wanted to replace a couple to see if there would be an improvement. The problem is, when I insert the adjustment key into the head, it does not engage the screw. I can't even feel where the screw is. It feels like the internal hex of the screw is stripped or possibly filled with dirt. I have an old broken sprinkler head so I pried off the rubber cover to see what the insides look like. It is obvious that the cover is a one shot deal and will not go back on properly. So, my questions are: 1. Do the nozzles wear out and have to be replaced? 2. Can the hex screw that holds the nozzle in get stripped, and if so, how do I get it out to replace it? 3. Are the parts for this readily available (new screws and new rubber head covers)? But mainly, how do I get out a stripped screw? Thanks for your time. Dave
