Chris Milot
Hello all,
I'm planning on building an outdoor bbq island and looking into the possibility of adding a sink to it. I'll be able to get water to it no issues by adding a tee to the main irrigation line before it reaches the valves. My question is in regards to drainage for the sink. I'm in Mesa, AZ and the house is on a slab. I have clear access to dig a trench to the side of the house where a kitchen sink is located which is about 30-40 feet away. Does anyone know if typically the drains go below the slab where I would be able to dig down and under the slab and tie in there or do these pipes usually run within the concrete slab? I know I will have to address venting it as well but first wanted to find out if this will even be feasible. Figured I'd ask before I start digging to see what is down there.
There is also a couple of cleanouts in my front yard that I may be able to tie into if that's an option.
Thank you!
Thank you!
