How to measure LSI?
Zenon2cubed
Manitoba
I want to calculate LSI using the Lenntech LSI Calculator
For conductivity, I already have a TDS meter that displays PPM, what measures [Ca2+] and [HCO3-]?
I'm thinking of getting the Well eXact EZ Photometer, does anyone have experience with this unit?
It can detect:
Total Alkalinity: 10 - 200 ppm
Total Hardness: 60 - 600 ppm
Total Iron: 0.03 - 8.0 ppm
Nitrate: 0.25 - 32 ppm
pH: 6.4 - 8.4
The hardness number is normalized to grains of calcium. So you could probably enter zero for Mg, and put 17.1*hardness (grains) into the calcium box.
DesertEaglePt50
Pennsylvania
I got the hardness test and alkalinity test from Hach. They are both quick and straightforward. You just need to make sure you mix thoroughly when you start to see the color change, because when you get close to the right number of drops you will see the color change at first but it will reverse with mixing. This is a more of a pitfall with the alkalinity test.
