JasonC
Hello everyone,
I am installing a reverse osmosis water filter system under my kitchen sink. Everything has been a breeze up until this point. I am having an issue with the water feed "T" between the water in line and the kitchen faucet. line. My issue is that there is a leak that occurs right under the grey fitting. I am not sure what exactly its called so I took a picture and drew an arrow where the leak comes from when I add the "T" in. The second picture is of the "T" itself.
My first thought was that the inside of the "T", was too constrictive causing back pressure on the water and than my other thought was that the Nut on the end of the T that connects to the water in feed line was too short with not enough threads which doesnt sit flush against the O-ring inside the grey connector which is allowing the pressure of the water to escape.
I was going to try to replace the nut with a longer one but haven't had any luck finding one. Any help is appreciated. Thanks - and in case its needed I am installing an Ispring 6 stage R/O system.
