Help with New Navien 210 Combi Boiler
Discussion in 'Boiler Forum' started by Fristar, Feb 6, 2019.
  1. Fristar
    Fristar New Member
    Feb 6, 2019
    New Jersey
    Hello,
    I installed a Navien Combi Boiler last month. The 210 NCB
    When it runs in the upper right corner of the unit you can smell a slight burned rubber or plastic melting slowly smell.
    It is not CO2 or Nat Gas. It was checked by a plumber for combustion.
    Plumber found no exhause least into the housing either to account for the smell.
    Boiler water temp set at 140 deg F so in normal operation.
    Navien will not just give me a answer on if it is a normal operation smell or new boiler smell etc.
    Any one have experience in this matter?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    I doesn't sound normal. Does it still smell when the output is set to 120F?
  4. Fristar
    Fristar New Member
    Feb 6, 2019
    New Jersey
    Yes but the slight smell lowers.
    When increased to 170 it gets more noticable.
    No combustion detected or nat gas detected. No CO2. Its odd.
    It is a new system, do they have a new boiler smell?
  5. djdavenport
    djdavenport Member
    Oct 4, 2017
    Santa Fe, NM
    I have a two-year-old NCB240e and it has always had a slight odor--generally in the area you describe. It's not a natural gas smell, but more like faint bakelite odor. Kind of plasticky. Ours loafs along at about 117 degrees on the coldest days, so it's not like it's ever nuclear hot. But, yes, it does have an odd odor. The unit has been otherwise problem free and all the settings seem to be in the normal range. No error codes, etc. So maybe it's just Eau de Navien.
  6. Fristar
    Fristar New Member
    Feb 6, 2019
    New Jersey
    Well this makes me feel a little better.
    Navien wouldnt give me a straight answer.
    I have 2 of these and they both have the smell, but was only concered really cause of the one at my house. Wanted to make sure safe with my toddler in the house.
  7. djdavenport
    djdavenport Member
    Oct 4, 2017
    Santa Fe, NM
    Well, I'm glad you were able to throw some real diagnostics at it. Much more confidence-inspiring than my nose.
  8. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    It's unusual to ever actually need 170F boiler output to heat the house, even during Polar Vortex disturbance cold snap events. At temperatures that high the raw combustion efficiency won't be better than 86-87%. If you have sufficient radiation (or thermal mass) on the system that it can be run at 120-125F without short cycling the efficiency will be well north of 90%. If that can work you can set up the outdoor sensor and run the system under "outdoor reset" control, using less fuel keeping the house at a steady constant temperature than you would using overnight/away setback strategies.
    Run a little napkin-math on the zone radiation to figure this out.
  9. Fristar
    Fristar New Member
    Feb 6, 2019
    New Jersey
    Its actually only to finish out the winter. I replaced a boiler running 180 deg water with this navien. Theres just not enough baseboard at the moment to heat house. I live in nj. Zero deg happens here nd at 140 it wont warm up. After winter ill be redoing all the baseboard in the house to match 140 deg water from boiler with the outdoor sensor.
  10. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Lots of boilers in NJ running 180F water never need more than ~140F-150F water to heat the house when it's 0F outside. Recovering from setbacks with 140F water can be pretty slow at 0F in those houses, but keeping it at 140F isn't a problem.
    Run a fuel-use based load calculation, and measure up how many feet of baseboard to figure out if it's even enough. Then run a room-by-room load calculation using a freebie online tool if you think some rooms need more. Resist the urge to micro-zone, but rather make the baseboard lengths proportional to the room loads. Make sure that all zones have enough heat emitter to deliver the full minimum-fire output of the Navien on their own when no other zones are calling for heat.
    If you take the calculated room load and divide by 300 to come up with the feet of baseboard (assuming it's a typical baseboard such as Fineline 30) it should be enough to heat the room at condensing temperatures at least 90% of the time at N.NJ type 99% outside design temps. eg, say a bedroom's load come in at 2789 BTU/hr using the loadcalc tool. 2789/300= 9.3 feet. Rounding it to 9 feet is fine, 10 feet is also fine, but 8' or 11' won't cut it unless you change the ratio everywhere.
  11. Fristar
    Fristar New Member
    Feb 6, 2019
    New Jersey
    Thank you. I will after winter when im able to expand the baseboard
  12. jac04
    jac04 Member
    Dec 11, 2013
    The upper right is the exhaust. The NCB manual states that either PVC or CPVC solid-core (not foam core) pipe can be used for the exhaust. I made sure that CPVC solid-core was used for mine. I have never noticed any plastic smell from my NCB-180E.
    What material is your exhaust piped with?
  13. Fristar
    Fristar New Member
    Feb 6, 2019
    New Jersey
    Cpvc
  14. MEPSTOCK
    MEPSTOCK New Member
    Feb 14, 2019
    London
    Hey dude,me too faced similar situation like you said.I have bought same boiler last year and it worked fine for some days.After some time ,some issues had started with that boiler.I left that boiler and bought brand new vaillant ecotec plus 637 system boiler .Now it's working pretty well.The heating of the room is quite good .
Similar Threads: Help Navien
Boiler Forum Need help dialing in a navien ncb 240e Jan 9, 2017
Boiler Forum Navien 240 calibration help please Jan 9, 2015
Boiler Forum Navien 210 CH NG Tuning help needed please Jan 1, 2015
Boiler Forum Need Help Tuning Navien CH-180 ASME Mod Con Combi Dec 12, 2013
Boiler Forum IBC Boiler wiring help Wednesday at 12:44 PM
