NoPlanB
We recently purchased a foreclosed cottage in Northern Michigan which had freeze damage. Township records show the house was built in 1968 fwiw. We're not sure if the burst pipe was to the domestic water system or the hot water boiler system. Fannie Mae had the house winterized probably last winter (after the fact).
It's obvious where the pipe burst - in a 11' x 17' addition between the original house and the garage. The floor is buckled in areas and drywall damage is evident primarily along one wall. The boiler is located in an uninsulated framed in room in the corner of the garage. The whole setup is a bit rusty, humidity in the garage seems to be really high the few times we've been there. Garage is uninsulated
We're going up this week to tear out the carpet and subfloor then call a plumbing heating contractor to evaluate the whole situation.
We have a Weil-McLain HE-4 Boiler. Natural Gas - 100,000 BTU - which sounds like a lot for a 900 sq ft cottage. The cottage is on a crawl space and there is no insulation in the floor joists, or along the interior block perimeter walls or rim joists. There is blown in cellulose in the attic. Not sure about the walls, you'd think it was insulated but hard to tell.
I do believe the home was probably built as a summer use only cottage then "upgraded" later to a year round home. There's a bunch of rotting straw bales in the backyard which probably was the winter foundation insulation.
I'm thinking if I repair the burst pipe, wrap all the water & hydronic heating lines with heat tape & insulation, insulate the crawl space perimeter block walls, rim joists & joists we could have a cottage we could use comfortably year round.
The biggest unknown is the boiler. If it needs to be replaced how much of an expense? If it's shot what are our alternatives? I prefer forced air heating or one of the new tankless wall mounted units.
Any advice or suggestions would be greatly appreciated.
