Glued PVC Trap Broken Below Slab - Repair Ideas?
Zane Bridgers
Northern New Mexico - Climate Zone 5A
As you can see, I sadly broke off the P trap for a tub, and the plumbing is mostly below concrete. I can access most of the glue joint where the P-trap takes its down turn, but there's concrete flush up against the back of that joint.
Option 1: Separate the glue joint and add a new trap (if possible)
Option 2: Glue along break and reinforce with a sleeve
Option 3: Cut out the concrete to expose the trap arm, cut and re-glue trap
Other ideas? Please share!
On Point Piping
New York City
View attachment 103203View attachment 103206View attachment 103209
If you could cut the cracked part flush with the top of the trap and put a transition coupling on it that should be the fasted and cheapest way to fix that.
