Keep the home fires burning..... have you ever heard this saying???
what do you think this means??
Its the same with a water heater.... If you have one that has worked great for
9 years or so and you shut it totally off, sometimes the thermocoupling just
quits...and wont hold the charge..... I have seen mostly issues with the thermocoupling...s ometimes the gas control high limit just gives up.... .
The whirlpools seemed to be very troublesome that way...including the re-set button on the fire wall going bad.... that can also happen on the Bradfords too....
I dont know what the newer thermopyle types are gonna do and what troubles the honeywell valves are gonna go through if you shut them totally off but they are far more fussy and prone to problems than the older style valves are....... The newer Honeywell and ICON valves are an absolute and total pain to light from the start up,, so why do you want to tempt fate this way??
that is why they have the vacation setting on the gas valve.... it just keeps things humming merrily along
on another note,,,,, it probably will cost you about 2 cents a day to keep the heater on vacation mode....
while you are on your 3 week vacation in Hawaii or Dubai ......
I dont think it will break the bank too badly
