LLigetfa
DIYer, not in the trades
I have terrible water quality that wreaks havoc on everything between the well and and the softener. The pressure switch is no exception. I've had to change out the switch before when mineral buildup under the diaphragm would keep the switch from turning on.
About 8 years ago I installed an EPS from Cary and hoped that by not having a diaphragm, it might be immune to this. Well... it is not, although it did last longer than the Square D switches I had before. One of the great features of the EPS is no nuisance low pressure trips. On the Square D, the low pressure trip point is not adjustable per se, in that it follows around 10 PSI below the cut-in. Due to the micronizer acting as a dole valve, high water draw would/could drop the pressure far enough below cut-in. When that would happen, the lever on the side of the switch would need to be held "just so" until the pressure climbed high enough. Try explaining that to the wife over the phone when out of town. The beauty of the EPS was that it could be reset by toggling the breaker without having to go down into the crawlspace.
Being frugal to a fault, I knew the EPS was on its way out as it was reading the pressure wrong but I was just compensating by changing the setpoints. As it degraded over time, I just kept bumping up the pressure settings until it reached the max. I figured then that it was time to order up a new EPS but unfortunately, it went downhill faster than I anticipated. The wife really got on my case today for having chosen standard shipping and not paying for faster shipping. What's a cheapskate to do? I wasn't about to go buy another Square D at this point.
I looked at the Square D I had with low cut-off and figured out that I could lobotomize it. I removed the little metal piece that trips it and so now it is a standard pressure switch.
A dollar saved is a dollar earned and I just earned 40 bucks in less time than it would take to drive to the store.
