Fleck 5600SXT 32k optimal setting
Monet33
LA
Hi,
Just bought a new Fleck 5600SXT 32k 1in bypass. 11x11x38 brine tank and 9x48 resin tank. Family of 2 using about 150-180 gallons a day with hardness of around 20 and little bit of iron.
Injector 1
DLFC -
BLFC 0.50
DF: Gal
RT: DF1b
CT: Fd
NT: 1
C: 23
H: 20
RS: RC
RC: 180
DO: 30
RT: 2:30
BW: 5
BO: 60
RR: 5
BF: 5
FM: p0.7
Any help would be appreciated, TIA
A little fuzzy on the hardness and iron... I presume this is a private well.
System info (not programmed)
salt lb/cuft = 7.5 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 1 ; ft3 resin = (nominal grains)/32,000
Compensated hardness = 24 ; including any compensation
People = 2.5 ; gallons affects reserve calc
Estimated gal/day = 150 ; 60 gal per person typical calc
Estimated days/regen = 6.12 ; Computed days including reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/, Single Backwash, black cam
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 23.0 ; capacity in 1000 grains
H = 24 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 150 ; Reserve capacity gallons
DO = 30 ; Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 5 ; Brine fill minutes
FM = P0.7 ; https://terrylove.com/forums/index.php?attachments/img_fleck5600sxt_flow-png.31592/
FM pix: http://terrylove.com/forums/index.php?attachments/img_fleck5600sxt_flow-png.31592/
Monet33
LA
Thank you for the quick reply and I have city water. Water hardness test strip showed in between result so I guessed at the number.
Monet33
LA
Waiting for hach water test kit now.
This is the report from my water company
Hardness (total)
2019–2021
ppm
10 active wells, 12 storage tanks
Range
110–276
Average
223
To convert to grains, divide mg/l(ppm) by 17.1
