jds
I've just installed in the Delta Cassidy Monitor 17 series tub and shower trim kit in a Delta R10000-MF rough-in valve and something's wrong with the temperature control. I can get temperatures ranging from 82°F to 91°F, but not pure cold or hot. At first I thought that I did something wrong with the hot limiter, but I've tried everything (including removing the limiter and handles and controlling everything with pliers). Then I thought that I may not have seated the cartridge fully, but I've removed, checked and re-installed everything with the same result. I have a sink on the same supply lines just a few feet away and get pure hot and cold from there (57°F on the cold and 116°F on hot), so the problem is not in the supply. Did I just get a bad cartridge or is there something else I may have done wrong here? Thanks!
-Jeff
-Jeff
