Decontaminating (and possibly sanitizing) dirty copper plumbing before putting into service
Rossn
Denver, CO
TLDR: I have some 1" copper that sat partially installed a long time, and is a bit gunky inside. Do I need to cut out the ends and physically remove the construction dust/gunk and then sanitize it? Or, is there a good flushing means to clean the walls of the pipe through flushing?
Background:
I recently picked up a part of my project that has been idle, which includes a 1" copper water supply trunk running about 70' out to the garage and apartment above it. The first 20' (through joists) was run maybe 5 years ago, with the supply end getting a ball valve maybe 3 years ago. The rest was run in recent weeks. I found the loose sticks of copper I had pretty gunky ran a damp, packed blue paper towel through them prior to install. They took a couple passes to get the towels coming out looking clean, and not darkened. What would you do with the first 20' that has been sitting?
Storm rider
Slave to rentals
Nevada
I would use a fish tape to run an alcohol soaked cloth through the pipe. You can also sanitize with bleach.
Rossn
Denver, CO
Thanks, Storm rider. with 2 offset sections, I couldn't run a fish tape, but was able to feed a wire down it, pull through some electrician's pulling twine and pull a rag through 4 times. All clean now.
