Correct fitting for back-to-back kitchen sinks
Nickel
California
I have a duplex and I'm moving the kitchens to the common wall. I'm wondering what is the correct fitting to connect the drains and vent. I see the Double Fixture is probably the correct fitting 2" for drain and vent, and 1-1/2" for the sink drains, but there are 2 different types, one is much wider with a longer sweep (Ferguson is about 5-1/2"), and one is compact with almost no sweep (Charlotte is about 3"). Is there a preferred option in this situation?
Also, tapping into the 4" iron stack there seems to be only one option which is the 4x4x2 san-tee, a very short sweep. Is this correct?
wwhitney
Berkeley, CA
I don't think that's correct, it sounds more like you're comparing a double fixture fitting from one manufacturer with either a double sanitary tee or a double combo from another.
Anyway, the double fixture fitting is the correct choice, e.g. this one:
I think the following is true or very close: on a double sanitary tee, the top of the side hubs will be definitely below the top of the top hub; on a double fixture fittings, they will be very close to the same height; and on a double combo they will be definitely above the top of the top hub.
Cheers, Wayne
Tuttles Revenge
Double fixture cross is the best fitting for back to back fixtures with a common vent. If the overall length is too much because each will stick too far into the cabinet, install it cross ways and use a 90° bend to stub out for each sink. Drains do not need to be centered in the cabinet.. and often work better for installing double basin sinks when they aren't.
Nickel
California
Cheers, Wayne
Thank you Wayne for the confirmation.
