John Shott
At long last, I've developed a serious leak in half of my radiant slab heating system. Although it is a single zone system with a single thermostat, I actually have four supply lines and two return lines. As a result, I have been able to continue to heat the half of the house without the leak by adding ball valves to shut off the leaky side.
I am worried that trying to repair the leak my be a losing proposition on California clay soil that expands and contracts with moisture level. As a result, I'm considering adding a manifold to run PAP lines up to the attic and down the walls to add hydronic baseboard heat to the currently unheated side of the house. At a later date, I will likely replace the side of the house that is still slab heated with hydronic baseboards as well. I hope to use my existing AO Smith boiler (that currently runs at about 130-140 F) to heat the existing/remaining slab AND the new baseboard radiators.
If I run lines up to the attic and then down the walls, should I add air vents at the high point of each manifold loop? It appears as if Mr Pex and Shark Bite offer manifolds to accommodate PAP-based systems with adjusting valves and flow meters on each loop.
While I'm still in the process of getting the appropriate thermal analysis to select baseboard tube lengths, are there other things I should be anticipating or planning for?
Thank you for your consideration,
John
John
