708.3 Where Required
Cleanouts shall be located in accordance with Sections
708.3.1 through
708.3.4.
708.3.1 Horizontal Drains Within Buildings
All horizontal
drains shall be provided with
cleanouts located not more than 100 feet (30 480 mm) apart.
708.3.2 Building Sewers
Building sewers shall be provided with
cleanouts located not more than 100 feet (30 480 mm) apart measured from the upstream entrance of the
cleanout. For
building sewers 8 inches (203 mm) and larger, manholes shall be provided and located not more than 200 feet (60 960 mm) from the junction of the
building drain and
building sewer, at each change in direction and at intervals of not more than 400 feet (122 m) apart. Manholes and manhole covers shall be of an
approved type.
708.3.3 Changes of Direction
Cleanouts shall be installed at each change of direction of the
building drain or horizontal
waste or soil lines greater than 45 degrees (0.79 rad) in the building
sewer, building drain and horizontal
waste or soil lines. Where more than one change of direction occurs in a run of piping, only one
cleanout shall be required for each 40 feet (12 192 mm) of
developed length of the
drainage piping.
708.3.4 Base of Stack
A
cleanout shall be provided at the base of each
waste or soil
stack.
I REST MY CASE
