Chicago DIY
Scenario:
1) Sewer gas smell in basement. Floor drains are holding water and I've replenished frequently. Smell is not coming from floor drain.
2) Smell seems to be coming where the foundation hits the footer inside an approximate 3ft section of the foundation. There is interior drain tile in the house attached to a sump pump. No smell from the sump pump or coming from the drain tile going into the sump.
3) Chicago house with exterior drain tiles installed for gutters. Clay
4) One downspout not being utilized...essentially open to the weather.
5) A catch basin was installed when the house was built (1923) however an addition was added on and the catch basin is in a crawlspace.
Question:
1) Is it possible that the non utilized downspout (completely open to the weather is the cause of this smell?
Im assuming the non utilized drain tile drains into the catch basin then into the main sewer line.
I plugged the non utilized downspout last night with a rag and the smell essentially went away.
2) Could the smell be as a result of wind/air blowing into the downspout, through the catch basin and the catch basin pushing air into the basement.
3) What is the purpose of a catch basin? Most of my neighbors in old houses have theirs outside. Mine is in a crawl space. At one time it must have been accessible but an addition was built over it. Do the downspouts drain into it?
4) Lastly, any maintenance I should do to the catch basin? Should I get in the crawl space and run water into it?
Curious on anyones thoughts and apologize for the lengthly post. Im really hoping this was the cause of the smell.
John
Question:
John
