Cast Iron Long Sweep
wwhitney
Berkeley, CA
Hello,
I'm starting to do some cast iron DWV plumbing, and I'm wondering what the cast iron long sweep is used for? The short sweep already has sweep matching that of an 1/8 bend, so per UPC 706.1 it should be adequate for any change of direction.
Also, UPC 706.1 generally requires a fitting of sweep at least that of the 1/8 bend for a change of direction, but UPC 706.2 allows a lesser sweep fitting, the sanitary tee, for joining a horizontal drain line to a vertical sack. Does this mean that for the special case of transitioning a drain line (that already has been vented) from horizontal to vertical, a regular 1/4 bend (whose sweep matches that of the sanitary tee) is allowed? I.e. is 706.2 implicitly modifying 706.1 to allow the lesser sweep in this one case?
Thanks,
Wayne
