Briggs Vacuity problems flushing.
Dellborg
Suffolk VA
In my first floor guest bathroom I'm on my second Briggs Vacuity that wont flush. The first one had no problems for about 5 years then started to where nothing would go down, so when I updated the master bathroom I moved that working Briggs Vacuity to the first floor guest bathroom and not long later it started doing the same thing. It seem strange to me 2 have do units having the same problem in the same location. Could it be a problem with the plumbing, may be the slope is not enough and a build up in the pipes is causing back pressure. Open to thoughts on what the problem might be.
Yes. It could be a partially blocked drain line.
Try dumping water into the bowl from a big container from as high as you can as fast as you dare. Maybe that will get things moving along.
Lou Donkle
Indiana
We had same problem on 2 Briggs Vacuity toilets. After 10-15 years the flush got worse and worse to where there was incomplete (no gurgle or glug at the end). Problem is the gasket or seal on the vacuum line between the tank and the bowl. First try to tighten the nuts connecting tank to bowl. If doesn't work, must remove tank and replace seal. I used a ton of plumbers putty and that worked fine. Toilets now flushes just like new! (Alternate search term: Fluidmaster VAC 1000 vacuum assist hardware in tank.)
