Jerry
My system is a hot water baseboard, all 3/4" copper pipe, multi-zone with separate circ pumps, built in 1998. There is some corrosion on the boiler and I'm researching replacements. I run an OA reset 150-180 and an indirect domestic hw tank. I have three Smith KS2008 hydronic kickspace heaters piped in parallel on three of the zones with mono-flo tees. The heaters are connected to the system via Entran Onix 1/2" tubing. Every single one stopped working and I found them plugged with rust deposits. I have no other evidence of this in the system and flow through my baseboards is good. Has anyone come across this? Where would the rust deposits come from and why would they accumulate in just the Onix tubing? Would you recommend using new Onix piping as a replacement? I don't have much room to work with for PEX or copper.
