Bathroom sink conversion, single or double?
opplumbinghub
Overland Park, KS 66204, USA
opplumbinghub.com
Friends,
I would love to hear your opinions and feedback on this post as i am trying to settle a bet and maybe even prove a point : )
Here is the situation:
Current bathroom vanity is a standard 72” cabinet with only one sink located on the left side that also shares a drain with a sink on the opposite wall serving the master bathroom.
Option 1: Replace the vanity with a single sink that is in the center, requiring moving the water locations and drain and also affecting the drain it currently shares with the master. Center is basically in between the two vertical copper pipes where the “blue # 1” is shown in the picture. NOTE these are 2x6 studs
Option 2: Replace the vanity with a double sink, leaving the plumbing for the current sink in place and only needing to move water and drain to the serve the right side while not disturbing the master sink drain. The new sink would basically be where the “blue #2” is shown in the picture.
Question one: What option do you feel would be easier or harder and how would you approach either option?
Question two: Regardless of which job is easier or harder, do you think a single sink that is on center is “cooler” than a double sink, or is a double sink the way to go?
Can’t wait to hear your thoughts and suggestions!
Jamie Love
View attachment 91393.
Looking at your bathroom situation, you've got two main choices here. You can either go for a single sink in the middle, which means moving a bunch of pipes around and messing with the drain that's connected to your master bathroom. Or, you could put in a double sink, which is way easier since you'd only need to add new pipes for the second sink on the right. The single sink in the middle might look cooler and give you more counter space, but it's definitely more work. On the flip side, double sinks are super handy if you share the bathroom, and they're pretty popular these days.
Honestly, if it were me, I'd probably go for the double sink. It's less of a headache to install, and you get two sinks out of the deal. But hey, if you're really into the look of a centered sink and don't mind the extra work, go for it! It's your bathroom, after all. Just keep in mind that moving all those pipes around could turn into a bigger job than you might expect. Whatever you choose, make sure it fits your style and how you use the space.
foplumbing
Florida
option 1 doesn't look like it'd be tougher to do.
Although, i can't figure out what the middle black pipe is for. I suppose something for a different floor in the house
John Gayewski
Iowa
We are in the middle of renovating our ensuite. Previously it was a 72" vanity with a centered sink. We would like to have a double vanity. My concern is all of the ABS drain/piping is 1 1/4". Are there any issues having a double vanity set up with 1 1/4" ABS piping? Each sink will have it's own drain and vent.
Start a new thread.
Edwards11
NPC
Friends,
Jamie Love
Hi Jamie! Based on your options, Option 1 (centered single sink) is harder due to the need to reroute plumbing and potentially affect the shared drain, but it offers a sleek and balanced look. Option 2 (double sink) is easier since it mostly uses existing plumbing while adding functionality and appeal, especially for shared spaces. Personally, I’d lean toward the double sink for practicality and resale value, but if aesthetics are your priority, a centered sink could be the way to go. ✨
