pcary@bw.edu
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I have a two-handle bathroom faucet that drips from the spout and I'd like to fix the drip. When I remove the handle and the hood attached to it, there is a stem sticking up with a plastic nut on it. (The nut allows the handle to turn the stem). The stem comes up from a white disc with a small v-shaped notch in it. I assume that the disc and the stem are part of a cartridge. Around that is a brass(?) collar that goes into the sink or the larger faucet assembly. I assume that to fix the drip, I need to remove the stem and disc and I will then find either a washer or rings that need to be replaced. I also assume that I should not be messing with the brass collar. Does anyone know how I get the stem/cartridge out and what I am likely to find under it? I have a good plumbing supply store, where I can take it and get whatever I need. I do not see a brand name anywhere.
Thanks very much.
Paul Cary
pcary@bw.edu
Thanks very much.
Paul Cary
pcary@bw.edu
