Advice needed for installing a compact garbage disposal
shop4eva
California
Hi Friends,
I am new to the forum and hope a expert can help me in my DIY project. I have attached the images on the configuration of the sink and disposal piping at the moment but really want to install a garbage disposal on top of this and hoping for some advice on how to do this and what brands will be able to achieve this.
Thanks in advance for your help.
The drawing below represents a sink with no sanitary tee. The drain is horizontal other than the required 1/4 inch per foot. "Combo or *" can be a combo wye+bend or it can be a lesser sweep. I think it is not permitted to be a santee on its side.
"E*" would be an elbow (horizontal to horizontal) that would bring the trap adapter away from the wall if needed. In your case, I think that should be a 45 degree bend.
I did not show the disposal/disposer in this drawing, so that the drawing could have further use. You would adjust as needed.
Dj2
California
It looks like you can work it out.
Most garbage disposers have their discharge drain at about the same height.
Remove the existing drain set and trap.
Assemble the new GD and attach the enclosed discharge to the unit, install the strainer and hang the GD. At this point the GD can be rotated in such a way that the discharge can fit into the trap. When you find the perfect position, tighten the GD and trap, then finish the electrical.
