Alex S
Hi all,
New to Houston and their lack of stocking ABS anywhere for a reasonable price, so I am going to use PVC to tie in a new main floor bathroom.
For vent pipes etc I have no issue using Transition Cement (Green) to go new PVC to existing ABS, but when it comes to the main drain exiting the house that will be reburied in Concrete, I become a bit more critical of my lax ways.
From what I understand the only approved for underground tie ins between different plumbing components is a mechanical coupling (a no hub / shielded / standard flex coupling).
Being a main drain it would be easiest to do this, because you can't really splice into a main drain and find room to glue the splice in anyways.
My question is for anything else like that ...Is a mechanical coupling for PVC to ABS really the only approved method?
Forgive my ignorance, but I have done some tests myself (maybe I am a fool testing a fools methods...and I know this) and I would bet a good chunk of change that a mechanical flex coupling would fail before transition cement.
Am I crazy?
Am I crazy?
