3/4" GHT Male - PEX connection
Larry5
PA
There has to be an adapter somewhere?
I put in an irrigation system in my garden by running 4 zones with 3/4" PEX (all crimp connections). At various locations and in each raised bed I terminated the PEX end with a 3/4" male adapter. Thinking that each of my small sprinklers and drip systems would just screw right into the connector like a garden hose.
The plan was good but came a little short at the ends. I realized that when I tried to connect to the male connector it would not screw on all the way to compress the washer...water was spraying everywhere until I realized NPT and GHT, while kinda looks the same....
So my search is for a brass or plastic, doesn't matter, 3/4" GHT Male x 3/4" NPT Female. Everything seems to be the exact opposite.
I did find a solution that would require two fittings at each (NPT Female to GHT Female, and then a GHT Male to GHT Male). I even searched for a 3/4" PEX to 3/4" GHT Male.
Has anyone seen this type of adapter?
