Which plumbing tool do I use to unclog a outside drain
Discussion in 'Drain Cleaning' started by dogwalker, Jun 5, 2013.
  1. dogwalker
    dogwalker New Member
    Jun 5, 2013
    Houston,Texas
    From a do it your-selfer I have a clog in my outside drain(I believe) just shy of the main Sewer.I've heard good things about HYDRA JET CLEANING vs a ROOT AUGER(clog could be tree roots or 25 yrs of crap) One of my challenges is that the outside drain cleanout in my backyard is 2.5 ft from the house,little room on both sides cause of ac compressor and gas meter.I have 31 ft from that pipe to my fence,so I have room between the draincleanout and my backyard fence..The drain cleanout is a t connection,toward the house and downstream to the sewer.The outside drain pipecleanout is roughly 2.5 ft down to the connection,pipe diameter is 4 inches.Do you think The Hydra Jet suits me better or the Auger?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Most of the pros on this forum recommend you seek a professional plumber for these kind of jobs. There opinion is based on the fact that equipment small enough for a novice to handle will not do the job, and the heavy duty professional equipment is seldom available for rent and even if you could get something that large, this equipment is extremely dangerous in the hands of a novice. You not only run the risk of damaging the equipment, the powerful equipment can easily take one's hand or arm off. I suggest that you consider the risks against the cost of a professional plumber for this job.
  4. hj
    sewer
    In order to remove roots with a hydrojet unit, you need a lot more pressure than any unit you could rent or afford to buy. They are normally used to remove grease buildups, but that is unlikely to be your problem once the pipe exits the house.
Similar Threads: plumbing tool
Drain Cleaning Plumbing story of the day: Drain Cleaners Nov 1, 2016
Drain Cleaning Could a plumber please explain residential underground plumbing to me? May 11, 2016
Drain Cleaning MURATIC acid.Can it be used effectively to unclog plumbing Jan 7, 2016
Drain Cleaning Affordable Plumbing Repairs in Sydney Sep 7, 2012
Drain Cleaning Plumbing Roof Vent Mods Dec 9, 2010
