When and how to test thermal expansion tank?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SteveW, Nov 27, 2010.
  1. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    On another thread there are some videos from Dunbar Plumbing showing the black, stagnant water that comes out of the air side of a failed thermal expansion tank. I am wondering how to test a thermal expansion tank? I tap on mine once a month or so to make sure the air side sounds different from the water side. Is that enough?
    Should we all be letting some air out of the Shrader valve periodically to see if there is water on the air side of the tank?
  2. ballvalve
    Dec 28, 2009
    northfork, california
    I think the best way to test a expansion tank is to not have one. That black crud is not a maybe, its a WHEN.
    Here are links from another discussion on those guys, take a look at the interesting products that are made specifically to displace the need for expansion tanks... especially the toilet tank filler-relief valve. Thats a unique one.
    So it seems Watts has provided an entire series of options to expansion tanks: here are a few links.
    http://www.watts.com/pages/_products_details.asp?pid=803
    Here is one that really surprised me - wonder if Terry knows of it:
    http://www.watts.com/pages/_products_details.asp?pid=855
    And another surprise - combo ball valve and thermal expansion relief valve for water heaters.
    http://www.watts.com/pages/_products_details.asp?pid=564
    I believe all of those superior to tanks in most conditions, especially the ballvalve with the port for a drain line.
    Here is a US Apollo for $50 plus: http://www.grainger.com/Grainger/APOLLO-Thermal-Expansion-Control-Valve-2ZXZ8?Pid=search
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Maybe I'm missing something, but it looks to me like these devices work about like a T/P. I can't see where the water goes that is released when these things open. A thermal expansion tank hold the expanded water until the pressure in the heater lowers. I find it strange that if these things are a suitable replacement for a thermal expansion tank that this is the first time in my memory that anyone has mentioned them.
  5. ballvalve
    Dec 28, 2009
    At least for the toilet valve, it goes nicely into the tank. The others can be plumbed to a drain.
    I believe we greatly over estimate the expansion issue, and a tank is better used for water hammer.
    Watts appears to say they are a suitable alternate.
  6. hj
    Watts MAKES them so what would you expect them to say, "These are substitutes for an expansion tank but are not as good, and also only duplicate the action of the tank's T&P valve"? They "dump" the water on the floor, except for the fill valve model which uses the "obsolete" tank ball operation. IF the expansion tank has failed, water will come out of the air valve when you depress the stem. The alternate test is to remove the tank, or drain all the pressure out of the water system, and then check for air pressure with a tire gauge.
  7. Terry
    Aug 17, 2004
    An expansion tank helps to buffer the sudden drops in pressure when someone else in the home uses a faucet.
    I like to have an expansion tank for that reason alone.
  8. ballvalve
    Dec 28, 2009
    http://www.watts.com/pages/_products_sub.asp?catId=64&parCat=325
    They offer tanks on the same page as the alternatives.
    Notice that unlike the Water heater T&P you can buy the valve combo's in 60, 65, 80 etc. preset ratings, so you are not duplicating the water heater valve, but making it the final line of defense.
    If our government knew anything about public safety, they would drop the ridiculous lead standards in valves and fittings and require
    instead a back up T&P with a pressure relief setting far below 150psi. THAT might save a life.
    I am only discussing houses with pressure reducing regulators and standard water heaters. Not closed boiler heating systems.
    I have that situation in a few homes and have no pressure spikes.
  9. Gary Swart
    Sep 1, 2004
    Yakima WA
    I can personally verify the value of an expansion tank. When I installed my PRV, my water heater T/P immediately began to trip when the water began to heat. Not knowing about expansion tanks at that time, I replaced the T/P, but the problem continued. After posing the problem on this forum, I received my basic expansion tank lesson. Several years later, no T/P leaks.
  10. jadnashua
    If an expansion tank is leaking internally, eventually, it will fill up with water. In the interim, it will start to get heavier from that water. A properly setup expansion tank has the air pressure preset to your static water pressure, and therefore holds minimal water. So, while it is known to be working, if you knock on it, it should sound hollow. If it ever feels heavy and sounds with a thud when you think to knock on it, it probably needs to be replace. If everything else in the house is working properly, you'd probably notice that the T&P valve weeping after using a lot of hot water.
  11. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I see some real problems with the pressure relief ballcock as it can easily be replaced by an unknowing person and remove the system protection.
    Personally I think the failure rate on expansion tanks is low enough that you don't have to worry about it.
  12. jasonbaur
    jasonbaur New Member
    Nov 15, 2010
    California
    I watched this video concerning expansion tanks a few days ago, I thought it was very informative.
    [video=youtube;1RCPrzjcIz4]http://www.youtube.com/watch?v=1RCPrzjcIz4&feature=related[/video]
  13. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    As is far too common that video (and most others aimed at the DIY crowd) had some good information and a lot of poor or downright erroneous information. That specific expansion tank was on a HEATING system, not a potable water system. The "relief valve" on top of the air separator is NOT a relief valve but an air vent. The air vent has no pressure relieving function.
  14. jasonbaur
    Nov 15, 2010
    California
    Oops Should I erase the video? I just liked how the video went over how to test for a bad tank.
  15. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    They wont work in the areas that REQUIRE an expansion tank.
Similar Threads: test thermal
Plumbing Forum, Professional & DIY Advice What is this test cap-like thing? Monday at 2:21 PM
Plumbing Forum, Professional & DIY Advice Testing plumbing with air, flux in pipes... Dec 27, 2016
Plumbing Forum, Professional & DIY Advice How to pressure test new water lines? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
