What's the difference between a Vent Tee and a Waste Tee?
El Dorado
I need to lower (6 inches) the drain pipe under my kitchen sink because it is to high to accomodate my batch feed disposal. I went to the store to pick up some fittings, but wasn't sure which tee to get, so I got both. Does it matter which one I use?
If you are lowering the kitchen drain, and the drain is vertical, you would use a Sanitary Tee.
Sanitary Tee
A Santary Tee Wye would not be used in the vertical position for venting. It would create an "S" trap in that position.
