What material to replace fascia boards with ?
Discussion in 'Remodel Forum & Blog' started by mckeand13, Jul 2, 2009.
  1. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    My house is a 1958 ranch located in WI. Cold and hot weather.
    I'm going to have my roof & gutters replaced and I'd like to replace all of the fascia board at the same time. there are some edges here and there that are soft/rotted, and plenty of spots that need paint. Doesn't seem to make sense to put new gutters right over questionable wood.
    What's the right material? I put some white pvc trim in a bathroom recently and it seemed awesome to work with. It seems like pvc would be the perfect material for fascia boards. No rot, no paint. I've noticed that HD has it in stock at 12' lengths for the 1x6's ($30 each).
    Is PVC a good choice for fascia boards? Any other materials or woods that are better in some respect?
    Any specific nails to use? Stainless, large head, etc....
  2. bsperr
    bsperr Member
    Apr 23, 2008
    Athens, GA
    I'm planning to replace my fascia and soffits with Hardie materials. Hardie trim comes in a variety of dimensions and is very durable. If you also have to replace some of your soffits due to rot, you should check out their pre-vented soffits. I would guess that pvc trim would work well, too. Either way, you would want to use stainless or galvanized (hot dipped) fasteners.
  4. jadnashua
    I'm not sure what Aztec boards are made of, but they have proven to be durable where wood was not in my building. Hardieboard is also very durable and should hold paint well for a long time.
  5. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Azek boards are made from PVC and are similar to foam core pipe. I personally do not like working with the stuff ... way too dusty and won't hold nails or screws well. I would suggest you go to a good yard and buy preprimed, finger jointed, red cedar.
  6. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
  7. 99k
    Aug 16, 2008
    As far as I know, they don't make "solid pvc". Read the description ... this is called "cellular" ... I call it foam core.
  8. hj
    trim
    I would use one of the "manufactured" woods. PVC can deteriorate when exposed to the elements.
  9. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    I'll have to see if I can find the name/mfg next time I'm at HD. I remember it being solid.
  10. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    What do you mean by "manufactured"? Real wood, or a look alike in other material?
Similar Threads: material replace
Remodel Forum & Blog What size and material sump pit or basin Feb 24, 2016
Remodel Forum & Blog Steam shower roughin - bill of materials Sep 18, 2014
Remodel Forum & Blog Ecological and green building methods and materials May 9, 2011
Remodel Forum & Blog Sealaing material around a dryer duct Jun 16, 2010
Remodel Forum & Blog What is the best tub material? Jan 30, 2008
