What determines hose bibb size?
DavidTu
Seattle, WA
For 2x4 walls with wood siding what determines the appropriate 3/4" tube length for a vacuum breaker non-freezing hose Bibb?
Gary Swart
Yakima, WA
Mine are 12" long, and that works just find in Yakima which sees colder temperatures than you get in Seattle, so that should be ample length for you. I really don't know if there are different lengths, all you really have to do is get them through the wall with enough length to work with inside. Main thing is to be sure you remove the hose in the fall before frost season. I have recently heard there are some that will drain even with the hose connected, but I haven't actually seen them so I can confirm or deny their effectiveness.
