Well Pump Wireing
Discussion in 'Electrical Forum discussion & Blog' started by Giles, Mar 26, 2009.
  1. Giles
    Giles Retired tool & Die and Mechanic
    Aug 28, 2007
    Retired
    N.W. Alabama--Florence--
    My submerged deep well pump stopped working. I am not physically able to pull the pump so I got the only well pump repairman that I could locate to do the job. As usual, he didn't do the job like I would have--in to big of a hurry.
    We found that the pump needed replacement and the existing connections were made with water tight connections. The repair man said they were not necessary so he used wire nuts to connect the wires at the pump.
    I do not like this since the connections are under water.
    What problems could this cause?
  2. Giles
    Aug 28, 2007
    Retired
    Yes he was licensed. I didn't have many choices. I made seven calls and no one was interested! I was without water for two days, pump went out Friday night.
    I will get someone to help me pull the pump and do it right!
    Ninety persent of the work I have done in my lifetime is redoing the work someone else did.
    I knew this connection was wrong, but the job was not nearly as complicated as I thought. Pump was about 125' deep. Needless to say, I will not use him again or recommend him.
    Thanks for the reply.
  4. acwilli
    acwilli New Member
    Mar 25, 2009
    Truck Driver
    Cannon Township, MI
    Well Pump wiring
    Personally I would call your township or city for the proper instalation guidelines. If this guy did not go by those standards, then he is subject to be sued if he does not fix the problem. I would say that there should not be a charge on it either.
    Good Luck aw
  5. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    I know this is beating a dead horse, but you will be lucky if the pump even runs at all.
    Even if the wire nut had a sealer inside, they will not last more than a day or so.
    If the (well guy), and I use the term loosely, has a license, he can be fined.
    Each state has a licensing board, and each well licensee can and is held accountable for his or her actions.
    Is there any reason given for no one else wanting to do the work?
    Travis
  6. Giles
    Aug 28, 2007
    Retired
    Every one that I called was retired or not physically able to do the work. Strange thing---THREE of these people recommended this person! Just my luck, one jackleg in my county doing this type work.
Similar Threads: Pump Wireing
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog Water pump will no longer work off generator. Jul 31, 2015
Electrical Forum discussion & Blog Pool Heat Pump and amps May 23, 2015
