The main problem is air in my lines. I have checked everything inside and all seems well. With the well cap off and ear in the pit the pump kicks on with a gurgles and sounds of spraying/dripping water can be heard faintly. When pumps turns off it sounds like water draining through the pipe and again dripping water(not sure what a well refilling sounds like).
After further inspection/diagnosis...
Upon opening the 6" well cap I find 3 wires, and a 1" female pipe level with the cap. Following this 1" pipe down into the well it comes to a connection with 4- 1/2" bolts. This pipe is in the center of the pit. I loossed 1 of the bolts to find water seeping through. Promptly I tightened it back down. I cannot see a pitless adapter.
After some research all I can make of this is that it is a well spool? Where the edges of this device touch the casing it look like it could be threaded.
My questions are.
If this is a spool how is it removed?
Could there still be a pitless underneath of this?
How do you recommend removing these bolts 4' down?
I am on the brink of having a professional take this one off my hands and really just want to know if all my efforts thus far have been in vain
before doing so.
Thanks
"I don't like hiring a pro unless I have to and I don't like DIY unless it's done"
My questions are.
Thanks
