Well Pump problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by P.C., Jun 7, 2005.
  1. P.C.
    P.C. New Member
    Jun 7, 2005
    I can't flush a toilet and wash my hands while the toilet is filling without my water pressure dropping to zero. I also can't run the hot and cold water togetherwith any kind of force without my pressure droppimg to zero. It's getting to be a real pain in the rear repriming 8 or 10 times a day. Any ideas how to fix this?
  2. Gary Slusser
    Retired
    Is the pump coming on when it is supposed to?
    Where's the pump?
    Do you have air in the lines when this happens?
    Gary
    Quality Water Associates
  4. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    Is it a submersible pump? Is it an above ground jet pump with a pressure switch directly attached...? What size is your pressure tank? Are you watering the lawn at the same time you are flushing the toilet and trying to wash your hands? How old is your well, and how deep?
  5. P.C.
    P.C. New Member
    Jun 7, 2005
    sOMETIMES I GET WHAT SEEMS LIKE AIR WHEN I REPRIME. I DON'T BELIEVE IT IS AN ABOVE GROUND PUMP. MY WELL IS ABOUT 40FEET DEEP. MY HOLDING TANK IS KINDA SMALL. ALL I KNOW IS I WANT THIS TO WORK...MY WIFE IS DRIVING ME CRAZY. CRIPES, YOU WOULD THINK I AM DOING THIS.
    HELP!!!!!! :( :eek: :mad: :confused:
  6. Gary Slusser
    Retired
    If you don't have an above ground pump, then there's no reason to prime. The time that takes may be allowing the well to recover some, and that means your well doesn't have the water in it that it used to. Or the pump to cool and run later.
    I think you need to call a pump guy or well driller or plumber that is capable of pulling the pump out of the well, and have things checked out.
    And.. ummm until you fix this she is going to be blaming you. This isn't one of those things she usually only wants to talk about and not have you fix. lol
    Gary
Similar Threads: Pump problem
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure pump problem Dec 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Air Lift Well Pump Problems Nov 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Problems pumping lake water to cottage Aug 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump problem May 10, 2016
