Well pump not working
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by maduck, Mar 22, 2007.
  1. maduck
    maduck New Member
    Mar 22, 2007
    Florida
    I have a 63' well. (It is used for watering my yard only) The pump stopped working so I called a repair company. The tech said I need a new pump and because of the limited access it will have to be pulled by hand. He wants to charge me $1050.00 to install a 1 hp Sta-Rite submersible pump. Can any one give me some instructions for doing it myself? My son is an electrician so I have no worries about changing the unit out once it is topside.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    That's a good price for the work he's going to do. But if you want to do this yourself, your going to have to give us more info on your well.
    No offense intended, but just because someone is an electrician doesn't mean they know how to wire a pump. Anymore than I would know how to wire a home.
    bob...
  4. maduck
    maduck New Member
    Mar 22, 2007
    Florida
    pump information
    What do you need to know? It is a 1 hp sta-rite submersible pump. The well is 63' deep. It has limited ingress/egress so it will have to be pulled out by hand.
  5. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    Is it on a pitless adapter? What material is the drop pipe made of? PVC? Galvanized pipe? What size?
    Since your son is an electrician, you should have him check out the system before you pull the pump. There could be a problem in the control box (if there is one). He should be able to check resistance in the motor windings to determine if the motor is bad, etc.
    Ron
  6. maduck
    maduck New Member
    Mar 22, 2007
    Florida
    more info
    The technician told me that the pump itself has gone out. He checked the wiring and the control box this morning. I am not sure what type of pipe was used. Is hand pulling the unit too big a job for the very handy homeowner? I have worked on just about everything around here and fixed most of my problems myself.
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    We can't answer this question until you tell us how the well is terminated and what kind of pipe it's hanging on. If you don't know the answers to these questions, we won't be very helpful.
    bob...
  8. maduck
    maduck New Member
    Mar 22, 2007
    Florida
    I will get the information and get back to the forum later today. Thanks for working with me. I have been reading some of the threads and seems like you know your stuff.
  9. maduck
    maduck New Member
    Mar 22, 2007
    Florida
    photo of topside
    I took a photo of the topside. Any ideas?
  10. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I see a galvanized tee on top of the well seal (the red rusty thing). The well seal has four bolts with 9/16 inch heads. Loosen all four about two turns. No more. * Do not take them all the way out.*Cut the PVC pipe then start pulling on the tee. It could be PVC pipe under the tee, it's hard to tell, but with galvanized pipe it's going to be heavier. The well seal will come up usually when you get to a joint. Just juke the pipe up and down bumping the bottom of the well seal until it pops out. It has a thich rubber seal sandwiched between four pieces of metal, two up and two under. It's advisable to have something to slip under the coupling of each joint while you unscrew the pipes and take a rest. A plate with a slot cut in it just the width of the pipe works good. Cut the slot to the center of the plate and have the plate large enough to sit over the casing. The rest is just all muscle.
    bob...
Similar Threads: pump working
Pumps and Tanks Well Forum & Blog. Water is life. How strong should the suction be on a properly working pump? Jan 6, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump not working Jun 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation pump not working May 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New Submersible Pump not working Mar 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Welcome problem in working on pump 3- phase ? Nov 6, 2012
