Well points
Ross cowell
Palm Bay florida
I am going to be installing a sprinkler system at my house in Palm Bay, Florida. I plan on a 1 1/2 hp pump, I have one well installed at 22 feet sized at 1 1/4 inch, my question is. What would be the recommended amount of well points, and what distance apart should they be from each other.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
One well point is enough if it can supply enough water. If it can only supply half the water needed, then two points are required and so on. Spacing the points as far apart as possible will help keep the cone of depression around one well from affecting the others.
