Well cap replacement, now metal sediment in system
brador
New York
I have a 170-foot deep well, copper and PEX throughout the house, and a Rheem Marathon plastic water heater, which we installed in late 2007.
I just had the well cap cover replaced and when I turned the pump back on, a ton of what appear to be small metal flakes shot through the system. I've been cleaning out faucet screens and fill-tube filters every 24 hours for a couple of days.
Now, the old water heater that came with the house and was in pretty bad shape when we replaced it. We had some problems with the particles back then, but it had long since subsided. This has been true even though we frequently turn off the water pump when we're away for more than a week or so--about six times a year.
I assume the particles are corrosion from some pipe or another, or from the old water heater. But the upsurge right after the well cap replacement has me wondering if it's something else. Also, what can I do about it other than wait it out?
Thanks, all.
After flushing out the stirred up sediment to the ditch, I would put a whole-house sediment filter for the water going to the house but not to the outside hose bibs. I like the Pentek Big Blue 4.5x20 housings. It is best to plumb in a 3-valve bypass around the filter.
I would also do a sanitizing of my well and plumbing. The first line of https://terrylove.com/forums/index....izing-extra-attention-to-4-inch-casing.65845/ has a link to a nice sanitizing article, but then I go into my possibly-overkill extension.
MI Well Drilling
Oh well !
Michigan
Chlorination will definitely stir up a ton of stuff. May want to test the water for bacteria before doing the sanitation. You'll be cleaning faucets for a month. Valve man has the right idea.
