RallyJon
Hello, first post. My house has identical toilets that date from a late '80s renovation. They all have occasional run-on problems, so I decided to re-fit them with new tank hardware. I just finished the first one using a Korky valve and Fluidmaster flapper, tube and flush valve seat.
Now, the water spot is much smaller than before. See the comparison below.
Also, the flush is now much more turbulent. Before, the bowl would fill quietly and then flush with less energy. Now, the water rushes in and swirls and flushes. I assume this is because the ratio of water from the tank to water already in the bowl is much higher.
I noticed some things when doing the re-fit. The original flapper was much closer to the bottom of the tank. The fluidmaster flapper closes when there is still a couple of inches of water in the tank. I have it adjusted to "9" for max flush volume, but shouldn't the tank drain almost completely?
The original refill tube was also too tall, just 1/4" below the flush button hole. The old fluidmaster valve that I removed also allowed the water level to go over an inch above the max water line cast into the tank.
So I'm guessing that a previous plumber had set it up that way to get more flush volume and a larger water spot. Is that dangerous, or can I re-do it the same way?
Thanks for any advice.
