Water shield premier water softener
jack richmond
Florida
I have a watershield premier water softener and it go through 1 40lb bag of salt in 24 hours. I have tried to find a manual for the settings but have not had an luck yet. can any one help me out?
thanks
Bannerman
Ontario, Canada
A photo of the control head maybe helpful.
Also helpful would be the age of the unit, tank size or total softening capacity, and the water type (municipal or private well).
jack richmond
Florida
Unit is 2003 i believe [not 100% sure on that]. I think its a 25 or 30 gallon tank olbut not sure about the softener capacity. Municipal water. Cant upload image for some reason.
Bannerman
Ontario, Canada
Resin tank size expressed as 9" X 48" (=1 cuft of resin), 10" X 54" (= 1.5 cuft), 12" X 52" (= 2 cuft)
Try setting the image size to low resolution as I recall this forum has a maximum image size limit.
jack richmond
Florida
Bannerman
Ontario, Canada
From first view, I'm not familiar with that specific controller. Are you able to obtain pics of the back and sides?
Is water running continuously to drain?
ditttohead
Water systems designer, R&D
Ontario California
Please post some pictures from the side and back. Fleck, Autotrol, Erie etc all make custom covers for many of their valves and their are many other valve manufacturers. I am not familiar with that cover either so without more pictures... not much I can do.
jack richmond
Florida
Is the "regen day" setting, how many times a day or how many days between regen?
Bannerman
Ontario, Canada
Some components appear to be Clack but I don't recall any Clack models with the arrow buttons stacked one over the other.
This site calls your valve model an "Aqua Pro" http://www.tcwater.ca/control-valves/ I couldn't locate any info on an Aqua Pro brand control valve.
Here's a link to a Clack WS1 Service Manual: http://clackvalves.net/pdf/documents/WS1 & WS1.25 service manual.pdf
User Manual: http://clackvalves.net/p/complete-service-amp-programming-manuals/ws1-ws125-service-manual/
A residential softener would not have multiple regeneration settings for one day. Since your unit appears to be demand driven (with a water meter), the regen day setting will likely be an override setting in case you have been away and the unit has not needed to regenerate over an excessive period. If your usual requirements require a weekly regeneration, the override might be set to 10 days to force a regeneration if one hasn't occurred in a 10 day period.
Is the liquid level in the brine tank unusually high and possibly overflowing onto the ground? There maybe a drain fitting on the side or back of the brine tank where excess fluid could be draining.
How many inches of water are in your brine tank? What are the dimensions of your tank? How high is the level of salt in your tank?
jack richmond
Florida
About 4 inchs of water. Tank is about 18" wide and about 3 feet tall. I usually keep one 40lb bag of dalt in it.
jack richmond
Florida
I'm trying to fix it myself. I am tenting the house and don't want to spend alot of money on it. A couple places i called said they will replace it for 450 to 550
Mikey
Hansville, Washington
Out of business.
Surprise, surprise. I'm no expert, but for "450 to 550", or close to it, I'll bet you could replace that controller with a modern, name-brand. See, for example, http://www.purewaterproducts.com/water-softeners. Size is dependent on hardness and use, however, which we don't know, and whether a softener alone is appropriate is dependent on your water chemistry, which we don't know. But, "municipal water" in this area is generally pretty good; you may not need anything fancy, but a softener would be appreciated by any woman with hair.
H2O Services
Water Treatment Specialist
Flint, Michigan
Clack Corp. makes proprietary front covers for many different water treatment companies. This company was rather short lived and little info is available anymore. This is a Clack valve with what appears to be a replaced (newer) control board. It can indeed regenerate several times per day if programmed that way. Although it would be rare to have one programmed as such. This has two regeneration settings; 1. Gallons (Set by the hardness setting calculated into the total capacity of unit). Your unit appears to be a 30,000 grain capacity softener. 2. Days over ride (This setting can be anything from 1 day - 30+ day over ride). So if the system does not reach it's gallon settings before the day over ride it will run the night of the over ride. If it is set for multiple daily regeneration's that gets rather complicated to explain how to re-program (highly doubtful that is the problem). I would generally set the day over ride at either 7 or 10 days. Do not replace it! This is a very good water softener and very dependable.
This link to an Impression Series by Water-Right has the manual you need.
http://www.water-right.com/library/documents/WR_Impression_Plus_Softener_Manual.pdf
Good luck,
H2O Services
Mialynette2003
Ocala, Florida
You need to get into the programming mode. Push the next & down button and hold for about 5 sec. This will start the programming mode. Hit the next to advance through eash program. There is a regen frequency. If it says 1, then it will regen every day. Set it to regen every 14 days. There is another area that should read AUTO, if not, the system is set as a timer unit and not a meter unit.
