myz8a4re
Hey folks, Im a newb here. I have repaired or replaced my toilets myself over the years. Toilets, flaps, fill valves, floats, seals, chains, handles etc... Im pretty sure the fill valve has just failed and I should get another but Im wondering what makes them fail? Yes my float is adjusted properly and yes I did a die test to check the flapper sealing, I can even pull up on the float and the water wont stop totally. So again, Im sure the valve just failed..BUT... Is there something I can check/repair? I know these valves are relatively cheap but I just replaced this one in March and instead of just grabbing another at the store I thought Id ask whats involved and what makes them go bad to where they wont stop the water from running into them. Im guessing I can either keep purchasing the cheap toilet parts or upgrade to something a bit more costly/reliable. I really appreciate any input!
EDIT: just to note, I do not have any worthwhile or higher end parts in my toilets, just the usual Wal-Mart replacement pieces off the shelf. Just incase someone was curious if I had any rebuildable pieces.
