Water-powered back-up sump pump ?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by cmw, Mar 13, 2010.
  1. cmw
    cmw New Member
    Mar 23, 2005
    New York
    I installed a sump pump that is functioning OK. Now I am worried about a power failure when I need the pump to be working. I'm reading about water-powered back-up sump pumps.
    My question is: are water-powered back-up sump pumps a reasonable solution or are there better systems to back up a sump pump during a power outage?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Considering they require the installation of backflow prevention which isn't cheap and the pump out 2 gallons of water while using 1 gallon to do it adding to the water to be disposed they don't seem very attractive to me.
    I would consider the battery powered Zoeller Aquanot II to be a much more attractive method and or, standby generator which brings in many additional benefits. The Battery can also be recharged with jumpers off a car in a long duration outage.
  4. JDE210
    JDE210 New Member
    May 5, 2010
    Leesburg, Va
    Hi cmw
    I will be installing a Zoeller Home Guard Max 503 this weekend. I will let you know how it works in my application. I too am concerned about losing power, and opted not for the battery backup systems, since batteries can fail. As far as it using two gallons of water for every one gallon of water removed, I feel that its a small price to pay for a dry basement.
  5. jbiddle
    jbiddle New Member
    Dec 22, 2009
    Canton, MI
    As far as the Zoeller literature states, the unit pumps out 2 gallons for every one used, not the other way around. I've had mine in for around about 9 months now and it's only turned on when I've tested it. I have a generator that I would turn to before needing the backup pump though. The backup is there for when the primary pump fails or if I lose power when away from home. Here's a pic of my setup:
    [​IMG]
  6. JDE210
    JDE210 New Member
    May 5, 2010
    Leesburg, Va
    Nice looking setup
    but the instructions specify to not use flexible material for the water supply. Any concerns with what you are using?
  7. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Well if you are going to use a water powered back up pump, might I suggest you install it to meet your local codes and to the manufactures requirements (not using flexible supply lines). By me most local codes do not allow it. It is a waste of water good drinking water 1 gal to every 2 gal it pumps out. There areas I seen them installed had a RPZ backflow preventer installed on the water supply.
    I have seen these units do some real damage to a basement when the plastic housing breaks and floods the home out with its own water supply.
    As for a good back up system let me refer you to an older post in these forums. http://www.terrylove.com/forums/sho...mp-Pump-system&p=173898&viewfull=1#post173898
  8. jbiddle
    jbiddle New Member
    Dec 22, 2009
    Canton, MI
    The instructions say not to reduce the water flow to the pump by using a flexible pipe. The pipe I used is similar to a water heater feed pipe and is rated to handle the full-flow of water through a 3/4" copper pipe.
    I was under the impression (mistakenly?) that a RPZ would not be required unless the connection was in the sump pit itself. I can certainly add a RPZ if it is required.
  9. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Its best to check with your local codes. Call your city's plumbing department and talk to the plumbing inspector, he will tell you what is needed for a backflow preventer. Some allow you to just installing a duel check.
  10. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    If you factor the cost of the battery, replacement over time, cost to charge and maintain battery charge, the cost of 1 gallon of water at what $0.0014 is the better way to go, besides the fact that batteries leak, off-vent gasses, have been know to cause house fires..............
Similar Threads: Water-powered back-up
Pumps and Tanks Well Forum & Blog. Water is life. Water-powered sump pumps Apr 9, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Back-up Battery Sump Pump --> Can you use two batteries? Dec 2, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Back-Up Sump Pump Nov 16, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Back-up Sump Pump won't stop running Sep 13, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Back-Up Sump Pump Which is better Aug 18, 2007
