Gdog
write diagnostic firmware for embedded industrial
Hi All,
Hoping for some expert advice on how to keep pipes from freezing in a an unheated (and un-insulated) attached garage.
The washing machine and laundry sink are out there in the garage roughly 10-15 ft from the nearest heated (and insulated) house wall. Again, the garage walls (that are not being shared with the house) are open; no interior sheet rock and no insulation. I live in the Pac NW so this is only an issue 2-8 weeks out of the year.
It's not a problem right now since I have a heater wire taped to the pipes in the problem area. When it gets cold enough to freeze, a thermostat in the wire allows current to flow in the wire which heats the pipe enough to keep it from freezing.
My question is this; eventually I want to insulate and drywall the garage walls (but not necessarily heat the garage). I would not think it's kosher to close up the walls with that heater wire taped to pipes, is it? The pipes go through the 2X4 garage wall studs (i.e. inside the wall); they're not mounted on top of the studs. What's the professional way to keep pipes in un-heated garage from freezing?
Thanks for any input, and as always, thanks to Terry for a great website!
