1. netmouse
    netmouse New Member
    84
    NJ
    I know one should replace rubber water hoses with metal. I did that to the connections to my toilets and on the washing machine. In the photo you can see the black water lines under my sink that go from the shut off valves up to the faucets in my kitchen. I tapped them and they are not rubber but instead seem to be a hard plastic. Is this normal and good?
  2. netmouse
    netmouse New Member
    84
    NJ
    I went to Home Depot today. They opened a box with a Delta faucet and it had water lines that looked just like mine. The water lines are integrated. Their website says it is Pex. The description has -"DIAMOND™ Seal Technology is the revolutionary water delivery system that combines a durable DIAMOND™ Valve with InnoFlex® PEX waterways."
    Read more: http://www.deltafaucet.com/smart-solutions/diamond-seal-technology.html#ixzz2zqG98Mjl
  3. SHR
    SHR Member
    85
    Minnesota
    They are normal. I have always had good luck with them as long as they are not cut shorter.
  4. cacher_chick
    3,236
    We have been seeing more and more plastic because only then the manufacturer does not have to prove that it is truly lead-free.
  5. Terry
    14,754
    Lead-Free is the new thing in plumbing.
    Lead free solder was done in the 80's, and now they're going after faucets. You will be seeing more and more plastics.
Similar Threads: water lines
Plumbing Forum, Professional & DIY Advice, Tips & Water heater connections to existing CPVC water lines Jan 27, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Calcification on hot water lines Jan 22, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Best way to splice double walled water lines Aug 24, 2013
Plumbing Forum, Professional & DIY Advice, Tips & No water pressure after bleeding. Should I cut the lines to my old washroom to fix? May 26, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Installing garage sink from water heater lines May 1, 2013
