Water heater supply line smaller than return?
Deathtofishy
Nevada
Couldn't find a post related to my question when searching, sorry if this has been answered.
I have a newer water heater in one of my rental units (installed by previous owner), and I am replacing all the old galvanized steel pipes in the basement with PEX due to corrosion and poor flow.
The 18" copper water heater adapters are both 3/4", but the supply line going to the water heater adapter is 1/2" and the return is 3/4".
The old galvanized was setup this way, so not sure if whoever installed it just followed what was there before, or if there is a reason for the smaller supply?
Never seen this before on the couple hot water heaters I've had to mess with in prior homes.
Can't imagine any negative switching to a 3/4" supply, maybe also even help with volume in the entire hot side?
Increase to 3/4 up until you split to supply hot to only one kitchen or one bathroom.
More volume (gallons) in the hot piping is a downside of bigger pipe (longer to wait for hot) but more flow rate (gpm) is good for the hot pipe to avoid pressure drops when the pipe supplies a bunch of stuff.
Deathtofishy
Nevada
Reach4,
Maybe my terminology in the first post wasn't clear.
The tee off the cold supply to the hot water heater is downsized to 1/2". That is what I am wondering if I should increase to 3/4"
The hot line coming out (what I referred to as return), is 3/4" until it splits to each of the individual fixture (faucets/bath/laundry), where it goes down to 1/2". Which I know to be normal/correct.
The water heater should be supplied with 3/4"
1/2 only works for two fixtures at a time. You should have 3/4" going in and out, and then break it down to 1/2 to the kitchen, the bathroom, the second bathroom, the washer.
These all get their own 1/2" lines off the 3/4".
Cold path to the WH should be 3/4 at least.
Hot path out of the WH should be 3/4 until you tee off to where 1/2 is appropriate.
