Water Heater Pan Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by molo, Jan 6, 2007.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    I'm placing an electric hot water tank in a closet next to the kitchen.
    1. How important is it that I have a water heater pan underneath it?
    2. How important is it that the pan be connected to the drain system of the home?
    TIA,
    Molo
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    How severe is the result WHEN it leaks? If you put in a pan, where does the water go WHEN it leaks?
    You could put in an alarm to warn you when it gets wet, if you are at home to respond.
    You get to make the decisions.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are 2 problems that will cause a wh to leak. The TP valve and the tank failing. Neither is likely to cause a huge flood all at once, but no leak is a good leak. The pan will catch the water that leaks in whatever amount. You do need a place for the pan to drain. It does not have to be into you home drainage system however. It can be piped to the outside either above or below the floor, whatever is best for the situtation. No matter what causes the leak or how large or small it is, the pan is just a temporary safeguard for a fairly short time against damaging your home.
  5. hj
    pan
    Whether the heater needs a pan or not depends on how much damage would be caused if the heater started to leak. If the pan does not drain to a safe location, (and you never want to connect it to the drain system), it will cause the same damage as if it were not there. The pan is not a proper receiver for the discharge from a T&P valve. That valve would overflow the pan in a very short time if it opens and discharges water.
  6. solsacre
    solsacre Plumber
    Nov 16, 2006
    Arkansas
    kitchen? probably first floor? don't worry about a pan...
    If you want it won't hurt... pipe it outside independently... and the T&P, pipe it on it's own.
    good luck
    dance-with-pumps
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    a plastic pan $$
    for only 5-12 bucks you can put the heater in a pan....
    even if you dont drain it anywhere its better than
    not having one.....
    if you can figure out a way to pipe it to a floor drain
    all the better
    or if you are on a crawl space ,
    simply pipe it into the crawl ...
    you might regret it some day....
    .if the t+p valve ever lets go...
    if you dont spend the 12 bucks today
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Out here a pan is code unless the heater is 20' from a finished basement area and must be piped to a drain or to the outside of the house unless it is not possible to. In that case it must be in a pan with a hose connection on the drain line stub. In all cases the T&P must be run to a 3" X 1" coupling facing up connected to the drain line coming from the pan with a 2" air gap.
  9. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    Do it. Best common sense 15 bucks you can spend. Just installed one a week ago with new heater.
    Mine holds quite a bit of water..
  10. Master Plumber Mark
    Feb 6, 2005
    floor drains
    it has been my experience that the
    floor drain that is only 3 feet away from
    the water heater is ALWAYS the highest
    point in the whole concrete floor....
    it always goes everywhere else first,
    when the t+p leaks or heater leaks...
  11. hj
    pan
    What earthly good is a pan if it is just going to dump the water on the floor, the same as the heater would if it started leaking?
  12. Master Plumber Mark
    Feb 6, 2005
    it cant hurt
    for the money a plastic pan is only 5 bucks.
    it cant hurt and it really depends on how
    fast the heater starts to leak....
    and at the very least you can contain and direct the water
    HJ on another note
    It also can keep you out of insurance claim troubles a
    year down the road if one decides to do some major damage.
    hearing the customer crying something like
    why didnt you at least put it in a pan for me ???
    I might have noticed it leaking before it did all this
    hidden damage
    IS YOUR insurance company going to cover my
    new floating hardwood flooor ???
    at the very least you can claim that you
    did all you could even if their is not a drain
    to be found anywhere....
    I have been there and done that.......
  13. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Funny that I've seen countless t&p's and pans installed with either no plumbing or just a pipe down to the floor...not going anywhere and virtually useless.
  14. hj
    pans
    Maybe they think the pans are magical and just having one under the heater will keep any water from damaging the house. If there is enough water to notice it in a pan, because the pan's drain is not exactly at the bottom, there will be enough to notice without the pan also.
  15. Randyj
    Nov 25, 2006
    Alabama
    I think either they're lasy or it's one of them "roundtuit" things.
  16. Mike50
    Jan 8, 2006
    Southern California
    Mine...appears to have had a slow long term leak which could have prevented the now powdery *permanent cement slab damage* with a pan.
    Get one.
  17. Cass
    Cass Plumber
    Nov 12, 2005
    I have seen plastic pans that the plastic was cut when the heater was installed and leaked. I only use the metal pans.
  18. Master Plumber Mark
    Feb 6, 2005
    whatever...makes you all happy
    if it is code, its code..
    the Oaty plastic ones seem to work ok.....
    if their is a drain nearby, all the better...
    if you are in business you should at
    least offer one to the customer......or make them sign off
    on it in your work order........
    or you could be shelling out some bucks 6 months from now
    if you get a bad one...because they will certainly bring it up...
    the water pressure around here runs anywhere from
    90 to 155psi
    so wehnever I get the chance, I ALWAYS
    pipe the t+p valve to the nearest drain....
    if the laundry is near by I usually will take the
    time to run some 3/4 cpvc into the laundry box
    I just sleep better that way......
  19. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I'm replacing a water heater tomorrow that has a pre-built galvanized pan that was designed for the condo units they are in.
    I'm getting a rash of these replacements all of a sudden and it has to be the weather. I have one tomorrow, saturday, tuesday and not counting this great sump $$$ pump weather that is going to be here starting tonight.
    I'm slowly approaching burnout stage if I don't start saying no to working on weekends.
  20. Cass
    Cass Plumber
    Nov 12, 2005
    Metal pans are required on gas heaters.
  21. nu2plumbingsf
    nu2plumbingsf New Member
    Feb 19, 2007
    new water heater installation
    Cass states that metal water pans are required for gas heaters but the ones I've seen here in the San Francisco Bay area are tinny aluminum Oatey brand; not very st urdy being just a bit thicker than a turkey pan and I'm worried it will puncture or tear on installation, especially since I will be placing 20" diameter short boy 40 gallon water heater on a 18" stand by myself with stand.
    I'm using an extra wide dolly to lay water heater down on styrofoam sheet pulling heater up so as to clear and then positioning stand and water heater pan on dolly and then just truck whole unit to site.
    Sound like a good plan, anyone? Water pan though worries me. I would think a heavy duty plastic pan is stronger or even better a good solid metal pan, the kind used to catch automobile oil but they don't come in larger than 20".
Similar Threads: Water Heater
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
