Water Heater Connections
Discussion in 'Water Heater Forum, Tanks' started by Odie130, Oct 25, 2011.
  1. Odie130
    Odie130 New Member
    Oct 25, 2011
    Oklahoma
    Attempting to remove copper pipe from water lines which are plastic. The problem is I cannot separate them. The copper pipe will turn freely but will not come apart from plastic fitting.
  2. Terry
    Aug 17, 2004
    That's right. It's a Uponor PEX fitting.
    You will need to cut the tubing and then reconnect them.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    Except you will need to have the special tool or homeowner connector device ready before you cut.
  5. Terry
    Aug 17, 2004
    Normally a water heater has 24" of metal piping before you convert over to PEX or CPVC.
    Being that is the case, we use 24" flex connectors, either copper or stainless steel. Not the braided supplies, but the corrugated supplies.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Those flex connectors are really the DIYers friend when it comes to water heater connections to any kind of pipe!
Similar Threads: Water Heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
