Water Hammer
Discussion in 'Irrigation / Sprinkler Forum' started by lrdecker1, Oct 5, 2005.
  1. lrdecker1
    lrdecker1 New Member
    Sep 29, 2005
    New house. Incoming water line goes to a tee. Off one side of tee there is a ball valve, pressure regulator then the entire hot and cold water system for the house. Of the other side of the tee is a ball valve, pressure regulator, about 50' of PVC line, backflow preventer, solenoid valves, lines to sprinkler heads. When the solenoid valves close, we get loud noise in lines in crawl space - water hammer. Installation of a new backflow preventer didn't have an effect (I thought it may limit a reverse pressure wave/surge in the PVC line and stop/reduce the water hammer). I saw an earlier suggestion I believe at your website to rebuild the solenoid valves but these are brand new valves. Does anyone make slow close solenoid valves? Will a tank with an internal rubber bladder absorb enough shock to reduce/prevent the noise? Do I need to install a larger diameter PVC line to reduce water velocity upstream of the backflow preventer and solenoid valves? How do I fix this?
  2. slb
    slb New Member
    Jun 17, 2005
    San Francisco North Bay
    I have a similar problem. I tried installing a water hammer arrestor, but it didn't work that well. Hunter makes some slow close valves, model HPV, that are supposed to suppress water hammer, but I haven't tried one yet. If you try it, please post back here and let me know if it works.
    -Steve
Similar Threads: Water Hammer
Irrigation / Sprinkler Forum New plumbing created water hammer noise in 3 irrigation zones Apr 10, 2014
Irrigation / Sprinkler Forum Second set of valves is causing watering hammer? May 25, 2011
Irrigation / Sprinkler Forum Water Hammer in lawn system Nov 24, 2008
Irrigation / Sprinkler Forum Water Hammer Aug 6, 2008
Irrigation / Sprinkler Forum Severe water hammer/slow close valves Jul 12, 2005
