hi. The house I live in has a tennanted apartment above me. I own the house.
When my tenants turn on their tub/shower, the sound of the water flow through the pipes in the walls is quite loud. I've tried clearing the air out of pipes and that helps a bit but only for a few days. The flow noise seems to be the problem. This doesn't happen when they turn on their kitchen faucet. However, their lever-style bathroom sink faucet causes a single clunk when it is turned off rapidly. This isn't typical water hammering since I've purged the pipes repeatedly to no avail.
This flow noise doesn't happen when I turn on the water in my bathroom or kitchen or laundry area. Same water supply.
I believe this all started when I replaced the tub spout with a Moen add-a-shower diverter spout from Home Depot to allow the use of a shower head. I also retiled the backsplash around the shower tap/spout at that time. In addition, at about the same time, I've noticed a very slow leak indicated by a spot on my ceiling under their tub area.
Is it the cartridge? it's an old Moen single pull-knob type of tap. Is it from the diverter/spout? Is it related to my pipes perhaps not being well secured behind the spout (I think not as when I screwed the spout on with teflon tape, the pipe felt like it was snugging up towards the back of the tile)? Maybe the cheapish Ikea bathroom faucet and/or it's cartridge? Is the pressure too high? Do I need an aspirator (not sure how those work)? I'm at a loss.
Any advice would be appreciated.
